Zurück   CnC Foren > Andere Spiele > (World of) WarCraft
Themen-Optionen Bewertung: Bewertung: 7 Stimmen, 5,00 durchschnittlich. Ansicht
  #391
Alt 05-11-2002, 18:15
Benutzerbild von M.C.M
M.C.M M.C.M ist offline
Hesse
M.C.M hat noch keine Bewertung oder ist auf 0
M.C.M eine Nachricht über ICQ schicken M.C.M eine Nachricht über MSN schicken
Patch 1.4
Patch 1.04:
FIXES
Fixed an issue related to full shared unit control and allied play that could cause one or more players to lose the ability to train or upgrade their own units.
Fixed an issue that caused the experience point bars in Battle.net profiles to improperly reflect recently gained or lost points.
Fixed a graphic issue related to the ladder profile and the scroll bar.
BALANCE CHANGES
Humans: Divine Shield duration increased to 15/30/45 from 10/20/30.
Humans: Divine Shield cooldown changed to 35/50/65 from 60/60/60.
Humans: Avatar cooldown increased to 180 from 120.
Humans: Resurrection mana cost reduced to 200 from 250.
Humans: Sorceress acquisition range increased to 700 from 600, improving the frequency with which Slow is auto-cast.
Undead: Banshee acquisition range increased to 700 from 500, improving the frequency with which Curse is auto-cast.
Undead: Anti-magic Shell is once again dispellable. A summoned unit under a shell does not take damage from the dispel, but will lose the shell.
Undead: Anti-magic Shell mana cost reduced to 50 from 75.
Undead: Sleep duration decreased on Hero units to 5/10/15 from 10/20/30.
Undead: Web duration decreased on Hero units units to 7 from 20.
Undead: Animate Dead mana cost reduced to 250 from 300.
Undead: Player-controlled Ghouls no longer turn off pathing against units when they are instructed to harvest lumber.
Undead: Possession now takes 1 second to cast, up from 0.
Orcs: Wards are no longer hit by Huntress Moon Glaive bounce.
Orcs: Critical Strike no longer receives damage from Thorns Aura. However, the Blademaster's base attack associated with a Critical Strike still interacts with Thorns appropriately.
Night Elves: Thorns no longer interacts with Critical Strike.
Night Elves: Mana Burn mana cost reduced to 50 from 75.
Night Elves: Mana Burn drain amount reduced to 50/100/150 from 100/200/300.
Night Elves: Mana Burn cooldown reduced to 7 from 9.
Night Elves: Huntress damage reduced to 1d3+14 from 1d3+15.
Night Elves: Metamorphosis cooldown increased to 180 from 120.
Night Elves: Cyclone duration reduced to 10/5.5 from 30/6 (normal unit/Hero units).
Night Elves: Starfall cooldown increased to 180 from 120.
Night Elves: Druid of the Talon (in Night Elf form) acquisition range increased to 700 from 600, improving the frequency with which Faerie Fire is auto-cast.
Night Elves: Ballista Impaling Bolt no longer functions with "Attack Ground."
Night Elves: Ancient Protector cost reduced to 160/80 from 240/100.
Night Elves: Ancient Protector hit points increased to 600 from 550.
Night Elves: Ancient Protector armor decreased to 1 from 2.
Night Elves: Ancient Protector minimum range reduced to 0 from 200.
Night Elves: Ancient Protector ranged attack damage reduced to 1d10+44 from 1d13+51.
Night Elves: Ancient Protector damage type changed to pierce from siege.
Night Elves: Ancient Protector splash damage reduced.
Creeps: Murloc Mutant damage increased to 1d5+24 from 1d2+12.
MAP CHANGES
Many minor changes were made to many maps due to the balance changes made in patch 1.03 and patch 1.04. Some examples include:
(4) Lost Temple - Added more shallow water to the islands. Center creep camp is a bit harder. Added Ogre Magi to the corner Ogre creep camps.
(6) Moonglade - Reduced all creep camps approximately 2 levels.
(8) The Crucible - All start locations should now be very similar, close to trees with enough room to build. All Goblin Merchant creep camps are now farther off the main path.
(10) Dustwallow Keys - Fixed the choke point in the bottom left. Moved Razormane creeps off the main paths.
(12) Ice Crown - Fixed the creep levels so that all camps are equal.
Alt 05-11-2002, 19:39
Benutzerbild von Psycho Joker
Psycho Joker Psycho Joker ist offline
Menefreghista
Psycho Joker hat noch keine Bewertung oder ist auf 0
Psycho Joker eine Nachricht über ICQ schicken
Hm, die haben die NE-Basisverteidigung ja ziemlich umgekrempelt... mal gucken welche Auswirkungen das hat.
ΑΓΕΩΜΕΤΡΗΤΟΣ ΜΗΔΕΙΣ ΕΙΟΙΤΩ.
BERGE BRAUCHEN KEINE MENSCHEN!
Alt 05-11-2002, 19:41
Hesse
Ich hab eben mal gespielt mit 2 freunden und wir haben eigentlich nichts verändertes festgestellt !
Alt 05-11-2002, 19:58
Menefreghista
Na ja, wenn die Ancient Protector jetzt Stich- anstatt Belagerungsschaden verursacht und keine Midnestreichweite mehr hat, dann ist das schon ne ziemliche Veränderung.
Bisher war die NE-Basisverteidigung eher weniger zu gebrauchen, finde ich.
Aber ma gucken, muss das erst noch ausprobieren.
Alt 05-11-2002, 20:11
Trunks Trunks ist offline
Trunks hat noch keine Bewertung oder ist auf 0
Trunks eine Nachricht über ICQ schicken
OL Nick: schueler0
mist jägerinen sind schwächer.......der DJ auch.STarfall hat nen längeren cooldown.jetzt wirts schwerer gegen diese UD (ich hasse guls)
Alt 10-11-2002, 17:52
Benutzerbild von Chaoskilla
Chaoskilla Chaoskilla ist offline
Chaoskilla hat noch keine Bewertung oder ist auf 0
Chaoskilla eine Nachricht über ICQ schicken
FUCK..................mee geliebten Nachtelfen haben n desem Update ja voll eins aufe Nase bekommen, we man mal von Ancient Protectors ab sieht.
Vor allem wurmt mch das die Jägerinnen und Manaburn schwächer gemacht wurden!!!!!!!!!!! :-(
3..2...1..LACHS *klatsch*
Reading motherfucker, can you do it?
Alt 12-11-2002, 07:54
Hesse
Jo hab ich in meinen letzten Games gemerkt
Alt 12-11-2002, 16:58
OL Nick: schueler0
hab zu random gewechselt..ist viel besser
Alt 12-11-2002, 21:29
Benutzerbild von camva
camva camva ist offline
Tarnpanzerlehrling
camva hat noch keine Bewertung oder ist auf 0
camva eine Nachricht über ICQ schicken
OL Nick: camva
Könnte auch sein das die Gamer einfach besser warn als ihr ^^#
und ja wenn man alle rassen kann sollte man imho random spielen da der gegner erst scouten kann und nicht sagen kann ach ich spiel vs XXX ich rushe/teche jetzt oder was weiß ich noch... aber ich spiel ungern Ork darum wechsele ich einfach mein Land nach belieben ^^
MfG
camva
Alt 13-11-2002, 14:59
Hesse
Ich nehm jetzt immer ein anderes Volk mal Untote ma Nachtelf ma Orcs.....
Alt 13-11-2002, 16:58
Benutzerbild von EviLSnipeR
OL Nick: ucdsniper
lol habt ihr probleme.
Als ich das erste mal seit mehr als 1em Monat wieder Warcraft III spiele mit dem neuen Update, hab ich gleich 2 mal hintereinander mit meinen lieben Orcs gewonnen
>>>>> Wikipedia Lexikon <<<<<
Alt 13-11-2002, 20:28
Hesse
LOL
Weil du jetzt 2 mal gewonnen hast denkst du bist der King mit den Orcs ? *g*
Alt 13-11-2002, 22:59
OL Nick: ucdsniper
Na logisch, was denkst du denn ?
Gell Camva ?
Alt 13-11-2002, 23:01
Tarnpanzerlehrling
OL Nick: camva
klar ^^
ach ja sucht ihr eigentlich noch wc3 clans?
ach ja kommt mal btT ;p
Alt 13-11-2002, 23:36
OL Nick: ucdsniper
Juhu ! Hab gerade wieder mal gewonnen... gegen einen 10er Rang hehe...
Bin endlich Rang 8... macht mir das mal nach... mit nem Modem !
btT ?
ähmm :o:
Ja... also... der Patch ist gut !
Alt 14-11-2002, 00:15
Hesse
btT ?
ähmm :o:
Nochma lol
Na und ? Was hat das mit Modem zu tun ? Bei mir laggts meistens auch mit DSL
Alt 14-11-2002, 01:44
Tarnpanzerlehrling
OL Nick: camva
lol ^^
ich bin erst happy wenn ich mein lvl 17 acc hab ;(
bin zu faul so viel zu laddern XD
Alt 14-11-2002, 07:45
Hesse
Level 17
Meiner is gerade ma Level 9... ich hab aber mehrere Accounts deshalb geht der nur kriechend voran
Alt 14-11-2002, 17:48
AAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHH.......................
Ihr habt alle Probleme......................ich bis gez drei oder ver mal im B-net gezogt ud drei mal gewonnen. a gut und auf LANs b ich auch immer dabei. Abver mal ehrlich de Zeit hätt ich garnich um regelmäßig m B-net zu daddeln ( wenn mal davo absieht das ich mit ISDN keine Flat hab wird gaz schön teuer) ;-)
Alt 14-11-2002, 20:28
Hesse
Ich zogg mindestens einmal am tag im battlenet
Alt 15-11-2002, 21:17
OL Nick: ucdsniper
Achja...
wenn ich doch nur DSL hätte könnt ich meinen Rang auch mehr verbessern... aber so hab ich ja schon Angst überhaupt wc3 zu spielen
Alt 18-11-2002, 18:11
OL Nick: ucdsniper
Hallo leute !
Ich habe lust heute abend mal ein bisschen Warcraft zu spielen ! Also ich werde so gegen halb 8 da sein oder früher.... mal sehen ob die Verbin´dung gut ist.
Also jeder der kommen will ich bin im channel "cncforen" (falls ich noch nicht da sein sollte könnt ihr es ja erstellen)
Alt 18-11-2002, 20:40
Hesse
hmm... mist heut kann / konnte ich net. Sag mir das nächste mal bescheid per PM dann werd ich bestimmt mit dir spielen
Alt 24-11-2002, 21:31
Benutzerbild von Horex
Horex Horex ist offline
Mirage Förster
Horex hat noch keine Bewertung oder ist auf 0
Ich finde WCIII genial Ich freu mich auch schon auf WoW Das wird bestimmt richtig cool Ich finde die Idee mit WC cool erfordert viel mehr Strategie als in den bisherigen CnCs, aber das wird wohl das CnCGen ändern Naja, welche Partei spielt ihr eigentlich am liebsten? Ich zogge am liebsten die Orcs die sind genial Aber die Elfen haben auch gute sachen! Die restlichen völker, also untote und menschen, find ich nit so prall, was meint ihr dazu? was ist eigentlich eurer lieblingsheld? meiner ist der klingenmeister der orcs
Alt 24-11-2002, 21:41
OL Nick: schueler0
welche rasse wurde ja schon gesagt.seit kurzem spiel ich orcs.der taurenhäuptling macht alles futsch.
WoW holl ich mir 100% schade nur das es monatlich kosten wirt.ist aber das einzig negative
Alt 25-11-2002, 08:02
Tarnpanzerlehrling
OL Nick: camva
AM/MK sind meine Lieblinge ^^# wobei ich eigentlich alle helden außer potm richtig gut finde
Alt 09-12-2002, 13:34
Benutzerbild von RedBasti
RedBasti RedBasti ist offline
Pyro
RedBasti ist ein C...
OL Nick: RedBasti
Orcs und Nachtelfen sind meine Lieblinge.
Als Held nehme ich gerne Dämonenjäger und Taurenhäuptling.
Ist eigentlich nen Add-on in Planung?
Alt 09-12-2002, 16:43
Hitman Hitman ist offline
Hitman hat noch keine Bewertung oder ist auf 0
Style: WarCraft
Bestimmt
Noch nicht offiziell, aber sie wollten sich an den Fans orientieren, ob die eins wollen... Außerdem müssten ja noch ne Menge Story-Fragen geklärt werden (Was passiert mit Arthas, Ilidan etc...)
Alt 11-12-2002, 18:47
Hm.......ein Add-on wäre echt nich schlecht!!!!!!
Ich denke aber das das noch was dauern wird bis das in den Regalen der Händler stehen wird.
Alt 14-12-2002, 20:39
songoten songoten ist offline
songoten hat noch keine Bewertung oder ist auf 0
im jahr 2003 soll es rauskommen,soviel ich weiss
Alle Zeitangaben in WEZ +2. Es ist jetzt 04:51 Uhr.
