Zurück   CnC Foren > Andere Echtzeitstrategie > Andere Echtzeitstrategicals
Themen-Optionen Bewertung: Bewertung: 1 Stimmen, 1,00 durchschnittlich. Ansicht
  #31
Alt 29-04-2016, 11:36
Neuer Patch ist live:
NEW FEATURES!
(PLAYER REQUEST): Added build placement UI so that it’s easier to see where you can build.
(PLAYER REQUEST): Added retry option for solo campaign missions and skirmish.
(PLAYER REQUEST): Changed difficulty level damage modifier to not apply to superweapon (nukes) or neutral player (environmental lava). This will make hard mode missions a little easier where the AI has nukes.
(PLAYER REQUEST): Setting a rally point on a non-primary factory makes that factory the new primary.
(PLAYER REQUEST): Resource nodes now go dark when exhausted and radar icon is also removed.
(PLAYER REQUEST): User MOD support for unit voice responses. (More information coming once we test this in a live environment).
(PLAYER SUGGESTION): Added backgrounds for several menus.
(PLAYER REQUEST): Invite functionality for Steam friends lists.
(PLAYER REQUEST): Adding in support to enable/disable superweapons in skirmish and multiplayer.
(PLAYER REQUEST): Changing sell/repair to work similarly. Pressing either one places you into SELL or REPAIR mode. Players can hold SHIFT to sell or repair MULTIPLE STRUCTURES. (We are looking for player feedback on this one.)
PLAYER REQUEST): Added scatter action for units. Pressing hotkey ‘L’ will now scatter units – helpful against getting run over.
(PLAYER REQUEST): Remove constant notifications for damage caused by lava.
CAMPAIGN ADJUSTMENTS
Fixed Starting Buildings so not in props (multiple maps) 4, 8, 9, 10, 11, 12, 13.
Mission 15 (Oil Can): Changed Text to 10 minutes to match actual objective timing.
Fix for a save/load issue in which player's structures were not being placed due to server side checks failing due to not loading a set.
BALANCE CHANGES
(GENERAL): Rocket Damage type bonus vs. structures reduced. This affects Rocket Infantry, Rocket Copters and Rocket Turrets.
(ROCKET TURRETS): Ground and air attacks have been separated out. While damage remains the same, attacks against aircraft are now AoE.
(ARTILLERY): Base damage increased and damage vs. vehicles increased. Firing speed increased.
(ROCKET HELI): Now requires Radar to produce.
(MG HELI): Build cost reduced.
(RADAR): Cost and Power reduced, build time slightly increased, effectiveness (range) also increased.
(COMMANDOS) Can no longer be crushed by tanks or harvesters.
(The Design Team will be watching the forums for feedback on these balance changes. Try it out, then let us know what you think.)
MULTIPLAYER
Additional delays fixed in multiplayer lobby messaging.
Disable multiplayer join button when selected match is full.
Disable multiplayer join button while waiting for a response.
UI: adding Discord and Twitch icons with links.
After playing invited match, player will return to associated match selection screen.
Fix for rewards showing garbage in tactical pause menu when in co-op.
Fix for player count not refreshing on multiplayer lobby.
Adding in text to show multiplayer is retrieving matches.
Don't allow multiplayer matches to start if there's only 1 human.
Fix for GoG Galaxy message not going away when logged into Galaxy.
GENERAL
Make sure objects contained in a transport that is destroyed are properly destroyed so that missions end correctly in annihilation mode.
CRASH FIX: [AI] Fix issue related to selling structures.
[AI] Prevent transports from unloading in impassable terrain.
UI: updating lock icon to white.
UI: Adjusted some of the selection colors.
Updated tooltips and object stats for balance changes.
Fixed floating boats and objects that didn't blow up on several maps.
Adjusted default FOW alpha setting to mid-range for new players.
Fix for game window not staying where you put it.
Updated the build tree in the manual.
Disabling auto-queue mode for now.
Alt 02-05-2016, 13:09
Sehr geil: PG hat die Audio-Schnittstelle geöffnet. Man kann nun beliebige 'Unit Responses' einfügen.
Ich hab aktuell die für TD drin, gibt es hier:
http://www.file-upload.net/download-...oices.rar.html
Man legt einfach im Ordner 'Data' die folgende Unterordnerstruktur an:
\MODS\AUDIO\EN-US
Da hinein dann die .mp3 Dateien und glücklich sein
Komplette Anleitung:
http://steamcommunity.com/app/427250...0166678192551/
Es gibt bereits einige weitere Zusammenstellungen, unter anderem aus Generals (da auch die deutschen USA), StarCraft etc. pp.
Alt 04-05-2016, 01:26
Neuer Patch: http://steamcommunity.com/app/427250...0166693661269/
Alt 04-05-2016, 21:16
Benutzerbild von ~Memento~
~Memento~ ist...
OL Nick: PsYcHo | Memento
Damit Du hier nicht den Alleinunterhalter spielst, coole Sache mit den Sounds
Muss auch wieder mal rein schauen, spiele gerade noch nicht regelmäßig.
Jedenfalls gut, dass sich da offenbar regelmäßig was tut bzgl. Patches.
Ansonsten scheint es hier ja noch nicht viele zu Interessieren bzw. ist ja auch fast kein Schwein mehr da :P Vielleicht solltest mal ein Newsletter an die User schicken ^^
IT Services
www.aitsolutions.at
Domains & Webhosting
www.webhostservice.at
Shisha Online Shop
www.shisha-island.at
LeXaRt Photography
http://www.lexart.at
Alt 05-05-2016, 18:11
Elmar Elmar ist offline
Elmar ist...
Elmar eine Nachricht über ICQ schicken
Ich hab jetzt Singleplayer einmal durch. Für mich nach dem Feierabend gut, einfach mal paar Missionen unkomplizierte Action. Nicht mehr aber auch nicht weniger. Klar gibt es wenig Abwechslung, aber bei "Z" gabs auch nur eine Fraktion und war lange unterhaltsam.
Alt 07-05-2016, 15:52
Geplanter weiterer Entwicklungsweg:
What's next for 8-Bit Armies?
Hi everyone!
We have been listening to your feedback, improving the core game, and figuring out what’s next. Now, a couple weeks after launch we have a plan we wanted to share with all of you.
SWITCHING GEARS…
Since April 22nd we have spent a great majority of our time responding to your suggestions for improvements, or helping with compatibility issues – or whatever happens to be on your mind. Four updates in the first two weeks (with another one planned for tomorrow) has kept us busy, but we wanted to be sure the game was in great condition before switching gears to adding more content - like our next faction. Over the next month we’re going to continue handling any issues that appear, but also slow down the frequency of patches as we switch back into “future content mode”.
COMING SOON?
Right from the start, we wanted to let you know we have plans to expand the game by placing a teaser on the main menu. We received some really great ideas from you on what we should do next, and where the existing single faction feels a little light. Today, we’re glad to announce that we have begun work on the second faction! We expect to share more information about it in about 2 weeks, and also start looking for beta testers around that time. We’ll put a call out for volunteers in the forums and in Discord chat as soon as there's something ready to play. Stay Tuned!
OTHER REQUESTS….
We have had many requests for more units, multiplayer features, and all kinds of other additions to the game – many of these feature improvements have already been added. We also know that a lot of people want to build, share, and play their own maps – and we’re happy to report that work on the map editor has already begun. It’s a big task and there are some obstacles to getting it ready but our goal is to get it released in May if everything goes well.
ROADMAP AND PRIORITIES
Since we’re a small team, and there is so much we want to do, there has to be some prioritization to determine what gets done first – mostly due to your feedback. Our plan (subject to change) for the next couple months looks like this…
MAY:
Ongoing Updates & Improvements
Map Editor!
More Maps!
Faction 2 Beta-Testing
JUNE:
Faction 2 Release
Additional Campaign (Co-Op/Single Player) Missions
Balance adjustments as necessary
Planning for what's next...
And somewhere in May or June we are planning to support localized content. We're currently working on this, but a delivery date has not yet been nailed down.
As always, we appreciate the great support you have for us, the development team. We read the forums every day and your posts are sparking lots of side discussions in the hallways here. Thanks again, and please continue to let us know what you think!
-8Bit
Neuer Patch:
GAME UPDATE #6 - 05/06 @ 16:00 (PST):
NEW FEATURES & CONTENT:
Added Co-Op Mission: 10 Commandos
Added Co-Op Mission: King of the Hill
(Player Request) Steam Trading Cards are now enabled! There are a total of 10 cards to collect.
(Player Request) Added easy difficulty option for Co-Op campaign.
(Player Request) Players can now drop structures within the normal build radius of their allies in skirmish & multiplayer modes. This can help in situations where your friend is getting picked on by an aggressive AI or enemy player.
(Player Request) Resource Slider: Allows players to increase the total amount of resource found on ALL oil derricks for that specific match.
(Player Request) Passwords enabled for private multiplayer game lobbies.
(Player Request) 8-Bit Armies: Audio: Reduced Win/Lose music back to default level.
Campaign objectives are now visible in the multiplayer lobby if in a co-op campaign game.
Name for multiplayer game can now be adjusted (it is no longer just the player's name).
GENERAL IMPROVEMENTS:
Even more improvements to lobby latency. We think (hope) this handles all remaining lag issues in the lobby for the last few people that were seeing them.
Added messaging when host hits the launch button so other players know something is happening.
Added version out of date warning to multiplayer match list display for those rare situations where a player can connect with an old client.
Added support for directed unit guard voice responses, as well as a GUI SFX for confirmation.
Better messaging to players regarding communication status / issues with connecting to the server.
Fixed inconsistency between build range with buildings of different sizes.
Fixed some extents to match grid cell placement logic better.
Fixed issue with AI not kiting tanks and harvesters when they should.
Fixed "Is it hot in here" nuke achievement.
Back-end UI improvements to support multiple factions.
Updated 8-bit font to have more/better glyphs.
Mission 19: Leapfrog - Several adjustments to make it a little easier.
Added 3 second delay after victory/defeat before movie plays so people aren’t sometimes surprised that the mission is over.
Engineer heal rate increased to 8/second (was 5/second).
Health bar on the commando has been raised such that it no longer impales his head.
Fix for game name to support mixed-case in lobbies.
Fix for transports missing control group text.
Added button states to the sell and repair buttons so players can more easily see that they are in Sell or Repair mode.
Slight increase to build distance to prevent issues with giving some players an unfair advantage when starting on certain start positions over others.
Alt 11-05-2016, 20:48
Clanwars.cc hat eine Ladder für 8BA online gestellt:
http://clanwars.cc/league_warriorrankings.aspx?GID=89
Alt 13-05-2016, 15:35
Neuer Patch:
NEW FEATURES:
(Player Request): Added a command bar in lower left which shows selected units. Can be hidden or unhidden, and units can be selected from within the group by selecting the sub-group.
(Player Request): Players can send money to friends playing on the same team. Can use the button in the upper right corner to bring up a special UI for this, or just click any allied unit or structure and click the “Insert” key.
(Player Request): Players can now ping the map with offensive and defensive pings. Default hotkeys for this are Alt-G and Ctrl-Alt-G, but we are looking to set these to something else in the future.
All player names are now shown in the upper right corner (used to be just players with nukes). Can be turned on/off/minimized by hitting the F5 key.
Added social buttons for Facebook and Twitter.
Co-Op campaign mission 1 and 2 difficulty were adjusted to make them more reasonable (especially for the first two co-op missions!)
All Co-Op campaign missions: AI no longer attempts to kite making it easier for players to use harvesters to crush AI infantry easier.
Added support for local player crate effects with HUD voice notifications.
Experimental audio fix for ASUS Xonar shutdown audio issues.
Changed video default to borderless fullscreen windowed. This will solve problems for some new players. This affects everyone, so just adjust back to your previous settings if you prefer.
Added check for "Enter" press while in the password entry dialog.
When hosting while logged into GOG, the hostname field now shows the proper GOG name not the computer name.
Fix for unpowered turret animations playing when not supposed to.
Added additional error messages for when joining a custom match fails.
Better handling of unicode player names.
Fix for nuke timer display showing correctly after a loaded save game.
Fix for unit production time being cut when transferring production between factories while unpowered.
Updated faction UI colors to be more legible in chat interface.
Außerdem kommt heute, wenn sie nicht schon freigeschaltet wurde, eine Demo raus. Diese enthält das Tutorial und die ersten 4 Missionen.
Alt 17-05-2016, 08:45
Benutzerbild von Vittel
Vittel Vittel ist offline
Ex-Nick: OliBeu
Vittel hat noch keine Bewertung oder ist auf 0
Vittel eine Nachricht über ICQ schicken Vittel eine Nachricht über MSN schicken
OL Nick: SwlssT4nk
Ich finds toll das Petro so fleissig patcht. Aber die neue Fraktion und 2-3 Maps sind langsam bitter nötig ^^
Alt 24-05-2016, 22:52
2. Fraktion kommt am Samstag Es ist
8-Bit Armies: Guardians is an additional military faction for the original 8-Bit Armies Real-Time Strategy game. Guardians includes new units and some additional structures to play with in both Multiplayer and Skirmish modes with the AI or your online friends. The additional faction is FREE at the moment for all 8-Bit Armies players and is forward and backward compatible with all previously released and future content for the game.
The Guardians Faction includes some common-use structures and units in addition to these new weapons of destruction...
Grenade Infantry: Throws deadly AOE grenades against ground targets for maximum damage
Sniper Infantry: Long-range infantry that can stealth while not firing on ground and air units
Rocket Car: Fast scout vehicle which is also useful against air and ground forces
APC: Unarmed infantry transport that can hold up to 10 units safely
Scorch Tank: Fires a deadly cone of fire at a target. When destroyed, causes a huge fireball that damages nearby enemies
Spectre Tank: Light tank unit with stealth capability. Reveals only when attacking ground-based foes
Siege Artillery: Longer distance artillery unit with a more focused impact damage radius
Anti-Air Drone: Autonomously hurls itself against enemy air units in the vicinity, exploding on contact
Heavy Drone: Heavy-weapons aircraft with both rocket and machine-gun capability which is good in all types of situations
Satellite Uplink: Controls the Orbital Cannon super-weapon to snipe units and structures from space with multiple rounds
Cannon Turret: Great defensive structure against enemy vehicles
Scorch Turret: Very effective defense against infantry units attempting to infiltrate the player's base
Alt 25-05-2016, 09:43
Ex-Nick: OliBeu
OL Nick: SwlssT4nk
Im Discord betteln alle für den Zugang zum Beta Testen... Die flippen fast aus ^^
Freue mich so auf NOD
Es fehlt eigentlich nur noch ein Replay system, dann wäre das Grundgerüst mal ziemlich abgedeckt.
Alt 31-05-2016, 00:14
Benutzerbild von teac5
teac5 teac5 ist offline
teac5 hat noch keine Bewertung oder ist auf 0
teac5 eine Nachricht über ICQ schicken
Mich gibts auch noch.
Hin und wieder spiele ich auch 8-Bit Armies. Ich war auch mal so frei und habe eine cncforen.de Gruppe bei Steam erstellt. Eintritt ist frei...
Alt 31-05-2016, 01:45
Nett gemeint... aber bei dem bisherigen Interesse hier?
Alt 31-05-2016, 10:38
Ex-Nick: OliBeu
OL Nick: SwlssT4nk
Ich joine heute abend mal wenn ich wieder zuhause bin. Spiele es eigentlich ziemlich aktiv. Wobei ich momentan mehr Zeit im Map editor verbringe
Alt 31-05-2016, 20:22
Schadet ja nicht. Vielleicht kann man dann auch mal die ein oder andere Runde zusammenspielen.
Alt 31-05-2016, 22:09
Benutzerbild von MRThomm
MRThomm MRThomm ist offline
MaJeSTrO
MRThomm ist...
OL Nick: DeSTr0yAX
bin auch mal beigetreten (aDe@thT0M)
Frage in die Runde, kennt eigentlich noch jemand den CnC-Clan aDe@th?
TARJA, WE L0VE YOU 4EvER!
Alt 22-09-2016, 15:31
~Memento~ ist...
*staubwegwisch*
so.. bin auch mal in der Gruppe ^^
IT Services
www.aitsolutions.at
Shisha Online Shop
LeXaRt Photography
Alle Zeitangaben in WEZ +2. Es ist jetzt 12:10 Uhr.
