Alt 05-11-2003, 17:41
Benutzerbild von ~Memento~
~Memento~ ist...
OL Nick: PsYcHo | Memento
geil find 1.7 Patch erschienen!!!
Englisch
- - Incoming transmission - -
General,
We have further tactical enhancements to improve your effectiveness on the battlefield. Please take the time to
review the following brief.
Generals Intelligence Agency
- - End transmission - -
Version 1.7 - October, 2003
Issues addressed:
1. FORCE FIRE - CHINA's Gattling Tanks can no longer force fire through buildings.
2. RALLY POINTS - Added rally points to the GLA Tunnel Networks.
3. IMPROVED ONLINE STATS - Made improvements to the code that tracks statistics and disconnects in online games.
4. CRASH FIX - Fixed a crash bug related to the Particle Cannon.
5. DESYNCH FIX - Fixed a mismatch that occurred when ordering a unit to attack right after they exited a building.
6. REGION ACCURACY - User tooltip in the Custom Match lobby now correctly displays the user's region.
7. HERO RADAR ICON - Jarmen Kell, Black Lotus and Colonel Burton now have a special icon on the radar map.
8. CHAT SOUND EFFECT - Added an audio cue to the communicator to alert users to an incoming message.
9. TEXT FIXES - Fixed text errors in the tooltips for USA Drone Armor and CHINA Nuclear Tank upgrades.
10. FIREWALL PORT OVERRIDE OPTIONS ITEM - Firewall Port Override values can now be set on the Options menu from the
Main Menu.
The game will need to talk to external servers that use the following port numbers. These ports need to be open in your firewall in order to play on Generals Online:
TCP ports: 80, 6667, 28910, 29900, 29920
UDP ports: 4321, 27900
If your firewall does not allow outgoing packets to open ports to incoming traffic, or you experience problems connecting to other players, you will have to specify which port you want Command & Conquer Generals Zero Hour to use for communicating with other players. To do this, go to the Main Menu and then select Options. There is a box labeled ‘Firewall Port Override’. Assign the port you want to use to the port override entry. After you enter a port number, be sure to hit Accept.
You will need to open the chosen port in your firewall for communication with players external to your firewall or NAT device. If you use the port override feature, the port you have chosen can not be masqueraded by a NAT device.
“Direct Connect” does not support firewalls.
Deutsch
- - Eingehende Nachricht - - General, Wir haben taktische Verbesserungen entwickelt, mit denen Sie auf dem Schlachtfeld noch effektiver arbeiten können. Bitte nehmen Sie sich die Zeit, die folgenden Worte aufmerksam zu lesen. Geheimdienst der Generäle - - Ende - -
Version 1.7 – Oktober 2003
Bearbeitete Probleme:
1. FORCE FIRE - Die Gatling-Panzer des Asiatischen Pakts können nicht mehr durch Gebäude feuern.
2. RALLY POINTS - Mehr rally points für das Tunnelnetzwerk der IBG.
3. VERBESSERTE ONLINE-STATISTIKEN - Der Code, der Statistiken und Verbindungsabbrüche in Online-Spielen aufzeichnet, wurde verbessert.
4. ABSTÜRZE - Ein Absturz, der mit der Partikel-Kanone zusammenhing, wurde behoben.
5. FEHLFUNKTION - Eine Fehlfunktion, die auftrat, wenn einer Einheit der Befehl zum Angriff direkt nach Verlassen eines Gebäudes erteilt wurde, wurde behoben.
6. REGION-GENAUIGKEIT - In den Hinweisen zu Missionen in der Lobby für eigene Spiele wird die Region eines Benutzers jetzt korrekt dargestellt.
7. HELDEN-RADAR-ICON - Infiltratoren, Black Bots und Kommandobots haben jetzt besondere Icons auf dem Radar.
8. CHAT-SOUNDEFFEKT - Ein Audiosignal wurde dem Communicator zugefügt, durch das Benutzer jetzt über eingehende Nachrichten informiert werden.
9. TEXTFEHLER - Textfehler in den Hinweisen zu den Upgrades für Drohnenpanzerung der WA und Nuklearpanzer des Asiatischen Paktes wurden behoben.
10. FIREWALL PORT OVERRIDE-OPTIONEN - Firewall Port Override-Werte können jetzt vom Hauptmenü aus über das Optionenmenü geändert werden. Das Spiel muss mit externen Servern mit den folgenden Ports Kontakt aufnehmen. Diese Ports müssen in deiner Firewall geöffnet werden, damit du Generäle online spielen kannst: TCP-Ports: 80, 6667, 28910, 29900, 29920 UDP-Ports: 4321, 27900 Wenn deine Firewall ausgehende Pakete an offene Ports für eingehenden Nachrichtenverkehr nicht erlaubt oder Verbindungsprobleme zu anderen Spielern auftreten, musst du Command & Conquer Generäle: Die Stunde Null mitteilen, welche Ports benutzt werden sollen, um mit anderen Spielern zu kommunizieren. Du kannst diesen Port im Feld "Firewall Port Override" in den Netzwerkoptionen des Optionen-Menüs angeben. Du wirst den ausgewählten Port in deiner Firewall öffnen müssen, um mit Spielern außerhalb deiner Firewall oder mit NAT-Elementen kommunizieren zu können. Wenn du die Port Override Funktion benutzt, kann der Port, den du ausgewählt hast, nicht durch NAT-Elemente verschleiert werden. “Direct Connect” unterstützt keine Firewalls.
IT Services
www.aitsolutions.at
Domains & Webhosting
www.webhostservice.at
Shisha Online Shop
www.shisha-island.at
LeXaRt Photography
http://www.lexart.at
Alt 05-11-2003, 19:20
[BF]dark-Rider [BF]dark-Rider ist offline
[BF]dark-Rider hat noch keine Bewertung oder ist auf 0
[BF]dark-Rider eine Nachricht über ICQ schicken [BF]dark-Rider eine Nachricht über MSN schicken [BF]dark-Rider eine Nachricht über Yahoo! schicken
Im Spiel merkt man keinen großen unterschied.Habe garnicht mitbekommen das der 1.7 patch bald erscheinen soll.
Alt 05-11-2003, 19:48
Zorg Zorg ist offline
Zorg hat noch keine Bewertung oder ist auf 0
No smile mehr nicht
Also da haben se aber ne ganze Menge weggelassen. Bsp.:Nuklear Geschütz kann sich aufgestellt bewegen.
Wenn es befördert wird kannes gleich noch einmal schießen (scheiße wenn ich mit ner fetten Panzerdivision angreife). Der Rocket Trooper Bug (CPU) (hab ein Forum wo alles drinesteht). Schwarzer Lotus kann Gebäude einnehmen und dabei sich noch bewegen.
Gibt bestimmt noch andere Sachen fallen mir jetzt aber nicht ein.
Alt 07-11-2003, 11:48
d-e-u-s d-e-u-s ist offline
d-e-u-s hat noch keine Bewertung oder ist auf 0
d-e-u-s eine Nachricht über ICQ schicken
Ich habe Generals uncut (Februar 2003, deutsch) und Zero Hour (english). language dateien hab ich angepasst, wie hier im Forum schon beschrieben wurde. Ich habe das Update von Generals von der Mainpage von cnchq runtergeladen und installiert. Das Generals uncut wurde auf Version 1.7 upgedated, aber Zero Hour steht laut optionen immer noch auf Version 1.0. Müsste da nicht auch eine Versionsänderung eingetreten sein?
Noch was: Was behinhaltet der Punkt: Verbesserte Online Statistiken? Ist nun das quitter-prob gelöst (JA/NEIN)?
<DANKE>
Alt 07-11-2003, 11:51
Benutzerbild von Alex0815
Alex0815 Alex0815 ist offline
Alex0815 hat noch keine Bewertung oder ist auf 0
hoff mit dieser kombination der versionen gibt es keine probleme .... hab nämlich die gleiche .....
hab aber bis jetzt die 1.7 noch nicht drauf gemacht .....
created by Alex0815
Alt 07-11-2003, 12:01
Wölfchen Wölfchen ist offline
Wölfchen hat noch keine Bewertung oder ist auf 0
RE: 1.7 Patch erschienen!!!
Original von PsYcHo
das gefällt mir :-)
hab die 1.7 selber noch net gezockt ist das wirklich so Nuke Cannon bewegen während aufgestellt, Lotus kann sich bewegen während dem hacken???
das mit der Nuke Cannon habe ich bei Zero Hour schonmal gesehen - da war sie aufgestellt und "rutschte" ein Stück zur Seite, aber nur um einem vorbeifahrendem Panzer Platz zu machen...
wo gibts denn ne liste mit allen den Spielfluss betreffenden Änderungen?
P.S.:
das geht garnet... hab grad versucht im lockeren Laufschritt mitm Laptop zu zocken und hab schon gegen nen Medium Enemy verloren - UNREALISTISCH :stick:
Alt 07-11-2003, 14:43
Dieser ganze Patch ist total verwirrend in der Readme steht drin unter anderem Tunnelbaugeschindigkeit wird erhöht. Ist doch in 1.5 schon längst geschehen doch jetzt in ZH wieder nicht.
Was soll der ganze Mist. :grr: :grr: :grr:
Alt 07-11-2003, 18:56
Benutzerbild von C4-s.
C4-s. C4-s. ist offline
ähm... welcher von den patches ist 'n jetzt für die Deutsche Generals Version?
Oder kann man dafür auch den Generäle Patch nehmen?
Alt 09-11-2003, 15:13
World-Builder World-Builder ist offline
World-Builder hat noch keine Bewertung oder ist auf 0
Grrrrrrrr!!!!
Och neee, schon wieder ein unvollständiger Patch.
@EA: Hey, die C&C-Fans werden ungeduldig bei soviel Schrott.
Wir fordern: Sofortiges Erscheinen eines vollständigen Patches 1.8!!!!!!!!
Alt 09-11-2003, 21:20
Bomber Bomber ist offline
Bomber hat noch keine Bewertung oder ist auf 0
kann es sein das mann mit 1.7 noch mehr Verbindungsabbrüche hat
habe gerade mit kumpel online gedaddelt und es war grausam alle 2-5 Minuten eine Unterbrechung
Alt 10-11-2003, 22:59
ForumSchlampe ForumSchlampe ist offline
[Banned]
ForumSchlampe hat noch keine Bewertung oder ist auf 0
gibts dazu eigentlich schon irgendwo nen multi crack? (bevor alle blärren, ich bin lediglich zu faul immer cds zu wechseln)...
Alt 11-11-2003, 13:29
Benutzerbild von Hydroxie_Koter
Hydroxie_Koter Hydroxie_Koter ist offline
Hydroxie_Koter hat noch keine Bewertung oder ist auf 0
Hydroxie_Koter eine Nachricht über ICQ schicken Hydroxie_Koter eine Nachricht über MSN schicken
Original von ForumSchlampe
Was verstehst du denn unter "multi" crack ?
Wenn du einen für generals 1.7 meinst, musst du noch warten
(bzw. haben die Sites, die ich kenne, ihn noch net)
Alle Zeitangaben in WEZ +2. Es ist jetzt 11:04 Uhr.
