Alt 20-06-2004, 14:26
w555
Guest
Beiträge: n/a
three tube BattleMaster tank shot point error code???? at re
whom be able to assist me w555 set three tube BattleMaster tank shot point error code???? at rest in
Object ChinaTankBattleMaster
; *** ART Parameters ***
SelectPortrait = SNBattlemaster_L
ButtonImage = SNBattlemaster
UpgradeCameo1 = Upgrade_Nationalism
UpgradeCameo2 = Upgrade_ChinaUraniumShells
UpgradeCameo3 = Upgrade_ChinaNuclearTanks
;UpgradeCameo4 = NONE
;UpgradeCameo5 = NONE
Draw = W3DTankDraw ModuleTag_01
OkToChangeModelColor = Yes
DefaultConditionState
Model = NVTBMaster
Turret = Turret01
WeaponFireFXBone = PRIMARY Muzzle01
WeaponRecoilBone = PRIMARY Barrel01
WeaponMuzzleFlash = PRIMARY MuzzleFX01
WeaponLaunchBone = PRIMARY Muzzle01
End
ConditionState = REALLYDAMAGED
Model = NVTBMaster_D
Turret = Turret01
End
ConditionState = RUBBLE
Turret = Turret01
End
; crate 1
ConditionState = WEAPONSET_CRATEUPGRADE_ONE
Model = NVTBMaster
Turret = TurretUp02
WeaponFireFXBone = PRIMARY MuzzleUp02
WeaponRecoilBone = PRIMARY BarrelUp02
WeaponMuzzleFlash = PRIMARY MuzzleFXUp02
WeaponLaunchBone = PRIMARY MuzzleUpUp02
End
ConditionState = REALLYDAMAGED WEAPONSET_CRATEUPGRADE_ONE
Turret = TurretUp02
WeaponLaunchBone = PRIMARY MuzzleUp02
End
ConditionState = RUBBLE WEAPONSET_CRATEUPGRADE_ONE
Turret = TurretUp02
End
; crate 2
ConditionState = WEAPONSET_CRATEUPGRADE_TWO
Model = NVTBMaster
Turret = TurretUp03
WeaponFireFXBone = PRIMARY MuzzleUp03
WeaponRecoilBone = PRIMARY BarrelUp03
WeaponMuzzleFlash = PRIMARY MuzzleFXUp03
WeaponLaunchBone = PRIMARY MuzzleUp03
End
ConditionState = RUBBLE WEAPONSET_CRATEUPGRADE_TWO
Turret = TurretUp03
End
Turret = TurretUp03
End
TrackMarks = EXTnkTrack.tga
End
; ***DESIGN parameters ***
DisplayName = OBJECT:BattleMaster
Side = China
EditorSorting = VEHICLE
TransportSlotCount = 3 ;how many slots we take in a transport (0 == not transportable)
WeaponSet
Conditions = None
Weapon = PRIMARY BattleMasterTankGun
End
WeaponSet
Conditions = None
Weapon = PRIMARY BattleMasterTankGunONE
End
WeaponSet
Conditions = None
Weapon = PRIMARY BattleMasterTankGunTWO
End ArmorSet
Conditions = None
Armor = TankArmor
DamageFX = TankDamageFX
End
BuildCost = 800
BuildTime = 10.0 ;in seconds
VisionRange = 150
ShroudClearingRange = 300
Prerequisites
Object = ChinaWarFactory
End
Experience#118alue = 100 100 200 400 ;Experience point #118alue at each level
ExperienceRequired = 0 200 300 600 ;Experience points needed to gain each level
IsTrainable = Yes ;Can gain experience
CrusherLevel = 2 ;What can I crush?: 1 = infantry, 2 = trees, 3 = vehicles
CrushableLevel = 2 ;What am I?: 0 = for infantry, 1 = for trees, 2 = general vehicles
CommandSet = ChinaVehicleBattleMasterCommandSet
; *** AUDIO Parameters ***
VoiceSelect = BattleMasterTankVoiceSelect
VoiceMove = BattleMasterTankVoiceMove
VoiceGuard = BattleMasterTankVoiceMove
VoiceAttack = BattleMasterTankVoiceAttack
SoundMoveStart = BattleMasterTankMoveStart
SoundMoveStartDamaged = BattleMasterTankMoveStart
UnitSpecificSounds
; These have the syntax of SomeNameSomewhereInCode = SomeNameSomewhereInLookupINIs
VoiceCreate = BattleMasterTankVoiceCreate
TurretMoveStart = NoSound
TurretMoveLoop = TurretMoveLoop
VoiceCrush = BattleMasterTankVoiceCrush
VoiceEnter = BattleMasterTankVoiceMove
End
; *** ENGINEERING Parameters ***
RadarPriority = UNIT
KindOf = PRELOAD SELECTABLE CAN_ATTACK ATTACK_NEEDS_LINE_OF_SIGHT CAN_CAST_REFLECTIONS VEHICLE SCORE
Body = ActiveBody ModuleTag_02
MaxHealth = 400.0
InitialHealth = 400.0
; Subdual damage Subdues you (reaction defined by BodyModule) when it passes your max health.
; The cap limits how extra-subdued you can be, and the other numbers detemine how fast it drains away on its own.
SubdualDamageCap = 800
SubdualDamageHealRate = 500
SubdualDamageHealAmount = 50
End
Behavior = AIUpdateInterface ModuleTag_03
Turret
TurretTurnRate = 120 ; turn rate, in degrees per sec
ControlledWeaponSlots = PRIMARY
End
AutoAcquireEnemiesWhenIdle = Yes
End
Locomotor = SET_NORMAL BattleMasterLocomotor
Locomotor = SET_NORMAL_UPGRADED NuclearBattleMasterLocomotor
Behavior = HordeUpdate ModuleTag_04
RubOffRadius = 150 ; if I am this close to a real hordesman, I will get to be an honorary hordesman
UpdateRate = 1000 ; how often to recheck horde status (msec)
Radius = 75 ; how close other units must be to us to count towards our horde-ness (~30 feet or so)
KindOf = VEHICLE ; what KindOfs must match to count towards horde-ness
AlliesOnly = Yes ; do we only count allies towards horde status?
ExactMatch = Yes ; do we only count units of our exact same type towards horde status? (overrides kindof)
Count = 5 ; how many units must be within Radius to grant us horde-ness
Action = HORDE ; when horde-ing, grant us the HORDE bonus
End
Behavior = PhysicsBehavior ModuleTag_05
Mass = 40.0
End
Behavior = FireWeaponWhenDeadBehavior ModuleTag_06
DeathWeapon = NuclearTankDeathWeapon
StartsActive = No ; turned on by upgrade
TriggeredBy = Upgrade_ChinaNuclearTanks
End
Behavior = LocomotorSetUpgrade ModuleTag_07
End
Behavior = VeterancyGainCreate ModuleVet_01
StartingLevel = ELITE
ScienceRequired = SCIENCE_BattlemasterTraining
End
; A crushing defeat
Behavior = DestroyDie ModuleTag_08
DeathTypes = NONE +CRUSHED +SPLATTED
End
Behavior = FXListDie ModuleTag_09
DeathFX = FX_CarCrush
End
Behavior = CreateObjectDie ModuleTag_10
CreationList = OCL_CrusaderTank_CrushEffect
End
Behavior = CreateCrateDie ModuleTag_11
CrateData = SalvageCrateData
;CrateData = EliteTankCrateData
;CrateData = HeroicTankCrateData
End
Behavior = SlowDeathBehavior ModuleTag_12
DeathTypes = ALL -CRUSHED -SPLATTED
ProbabilityModifier = 25
DestructionDelay = 200
DestructionDelayVariance = 100
OCL = FINAL OCL_ChinaTankBattleMasterDebris
FX = FINAL FX_BattleMasterExplosionOneFinal
End
Behavior = TransitionDamageFX ModuleTag_13
ReallyDamagedParticleSystem1 = Bone:Smoke RandomBone:Yes PSys:SmokeSmallContinuous01
ReallyDamagedFXList1 = Loc: X:0 Y:0 Z:0 FXList:FX_BattleMasterDamageTransition
End
Behavior = FlammableUpdate ModuleTag_21
AflameDuration = 5000 ; If I catch fire, Ill burn for this long...
AflameDamageAmount = 3 ; taking this much damage...
AflameDamageDelay = 500 ; this often.
End
Geometry = BOX
GeometryMajorRadius = 13.0
GeometryMinorRadius = 9.0
GeometryHeight = 10
GeometryIsSmall = Yes
Shadow = SHADOW_VOLUME
ShadowSizeX = 45 ; minimum elevation angle above horizon. Used to limit shadow length
End
Weapon.INI
Weapon BattleMasterTankGun
PrimaryDamage = 260.0
PrimaryDamageRadius = 5.0
ScatterRadiusVsInfantry = 10.0 ;When this weapon is used against infantry, it can randomly miss by as much as this distance.
AttackRange = 2600.0
MinTargetPitch = -15 ; we may not target anything outside of this pitch range
MaxTargetPitch = 15 ; ditto
DamageType = ARMOR_PIERCING
DeathType = NORMAL
WeaponSpeed = 999999.0 ; dist/sec (huge #118alue == effectively instant)
LaserName = AvengerTargetingLaserBeam
LaserBoneName = Muzzle01
FireFX = WeaponFX_AvengerTargetDesignator
FireSound = LaserCrusaderWeapon
RadiusDamageAffects = ALLIES ENEMIES NEUTRALS
DelayBetweenShots = 100 ; time between shots, msec
ClipSize = 3 ; how many shots in a Clip (0 == infinite)
ClipReloadTime = 700 ; how long to reload a Clip, msec
;WeaponBonus = DRONE_SPOTTING RATE_OF_FIRE 200%
;WeaponBonus = DRONE_SPOTTING RANGE 200%
;WeaponBonus = DRONE_SPOTTING DAMAGE 200%
End
Weapon BattleMasterTankGunONE
DeathType = NORMAL
LaserBoneName = Muzzle02
End
Weapon BattleMasterTankGunTWO
DeathType = NORMAL
LaserBoneName = Muzzle03
End
Alle Zeitangaben in WEZ +2. Es ist jetzt 21:58 Uhr.
