Alt 29-03-2007, 11:35
Patch 1.2 is out!
Gerade auf Krawall gefunden:
Gestern erst berichteten wir über die Bereitstellung des ersten Updates für „Command & Conquer 3: Tiberium Wars“. Wie EA nun berichtet, wurde die Veröffentlichung des zweiten Patchs auf Version 1.2 nun von Ende April auf morgen vorgezogen.
Wie gehabt wird sich das Update nach Release automatisch über die Onlinelobby beziehen lassen. Im Mittelpunkt der Verbesserungen sollen vor allem Bugs und Fehler stehen, von denen Spieler über das Support-Forum berichtet haben.
http://www.krawall.de/web/Command_+_.../id,24323/s,,c
Alt 29-03-2007, 11:53
Cool, lange brauchen wir wohl nicht mehr zu warten
Auch im offiziellen Forum von Predator zu lesen:
Hi guys,
We realize that the launch of Command & Conquer 3 hasn’t been completely smooth, and while some initial bumps are to be expected for most software releases, we want you to know that we’re actively working on addressing all the issues that are being reported online as possible in the form of a 1.2 patch, which we intend to release in the next 12-24 hours. Here’s what that patch will address:
1. Disconnects or freezes in the game lobbies
We’ve noticed that the game can sometimes hang for a bit, freeze altogether, or boot players back out to the main menu when they’re simply chatting in the online lobbies. GameSpy addressed part of the problem by implementing a server-side change late last night, and the frequency of this problem seems to have significantly diminished. However, we do know that some people are still experiencing this problem, and we are investigating several options to tackle this issue on our end as well. We’re hoping that the 1.2 patch will have additional fixes for this lobby hang/freeze problem.
2. Frequent lobby refresh
The game lobbies are refreshing themselves very frequently right now, which makes clicking on and joining games somewhat frustrating because of the constantly shifting/resetting scrollbar. This issue will be fixed in the 1.2 patch.
3. Updated patcher
The patch itself will update the Command & Conquer 3 patch utility to ensure that the problems encountered with the 1.1 patch don’t happen again in the future. Specifically, some users weren’t prompted to download the 1.1 patch automatically when they went online in the game or clicked on the Check for Updates button on the Command & Conquer 3 Control Center. This fix should prevent that from happening again.
As previously mentioned, this patch should be ready for launch in about 12-24 hours. We’ll have an automated downloadable version, as well as a self-extracting patch for those that wish to install it manually. We’ll have an updated ETA on 1.2 a little later on today.
Additionally, we’re tracking other issues that are unrelated to the forthcoming patch.
1. Sluggish reporting of match results
Many games are taking longer than anticipated to report their results (up to two hours) to the ranked and unranked 1v1 and 2v2 ladders. We are weighing several potential solutions to address this problem on our end, though the most likely fix for this issue will come from GameSpy in the form of a server-side change that will go live sometime this evening.
2. Registration problems
A small number of users have noted problems while attempting to register. Command & Conquer 3 uses an application called EREG to register the game, and EREG requires Flash to be installed on the user’s machine. If you’re experiencing a crash with EREG, make sure that you have the latest version of Macromedia Flash installed on your computer.
3. Inability to connect to Command & Conquer Online
If you’ re having trouble connecting the game online, make sure that Command & Conquer 3 is included in your router’s firewall exemption list (you may have to set this manually). Likewise, some virus protection software many interfere with the game’s ability to go online, so you may want to try disabling any such software that you have running in the background. Lastly, reference the game’s readme for instructions on how to open up additional ports on your router if you continue to have trouble connecting to Command & Conquer Online.
Again, thanks for bearing with us. We appreciate your patience as we get through the initial teething of Command & Conquer 3.
-Predator
Quelle
Alt 29-03-2007, 11:54
surfer7 surfer7 ist offline
Wenn EA so weitermacht mit dem Support, wärs super!
So fühlt man sich als Kunde echt ernstgenommen.
Alt 29-03-2007, 12:27
Tja, und wieder nix mit Maus-Umstellung?
Alt 29-03-2007, 12:34
mowfax mowfax ist offline
mowfax hat noch keine Bewertung oder ist auf 0
Nuja mal im Ernst, ich glaub die haben grade andere Sorgen als die linke Mausumstellung ^^'
Alt 29-03-2007, 12:37
Da ist sicher nicht alles drin was sie bis Ende des Monats zu 1.2 bringen wollten... ...klar... ...ist wohl eher ein 1.15 Patch...
Alt 29-03-2007, 12:38
Benutzerbild von Cabal...
Cabal... Cabal... ist offline
@ Sven:
Zitat von Gambler(C&C Inside)
Im Forum hat jemand herausgefunden, wie man bereits jetzt die alternative Maussteuerung von C&C Tiberium Wars nutzen kann.
Dafür muss man in einer Datei lediglich eine Zeile hinzufügen. Allerdings ist das Ganze noch absolut experimentell. Daher wird dringend davon abgeraten, dies mit dieser Methode zu tun. Wartet lieber auf die offizielle Freigabe, welche höchstwahrscheinlich mit dem großen Patch ende April kommen wird.
Also wie gesagt, ihr tut das auf eigenes Risiko!
Unter C:/Dokumente und Einstellungen / -eurer Windowsbenutzername- / Anwendungsdaten / Command & Conquer 3 Tiberium Wars / Profiles / -euerCNCNick- findet ihr die options.ini. Öffnet diese mit einem Texteditor, zum Beispiel Notepad, und fügt am besten in die 2. Zeile folgendes ein:
AlternateMouseSetup = yes
Der Ordner Anwednungsdaten ist unsichtbar. Damit ihr diesen sehen könnt müsst ihr im Explorer folgendes tun:
Extras- Ordneroptionen - Ansicht - verstecke Dateien und Ordner anzeigen
Nochmal die ausdrückliche Warnung! Dies ist rein experimentell und es wird davon abgeraten, das alternative Maussetup in diesem Status zu testen!
Quelle
(Klick mich)
Alt 29-03-2007, 12:40
Wohl schon implementiert aber noch nicht zu ende getestet... ...also ich hab mich schon dran gewöhnt nachdem ich gestern 6 Stunden LAN gezockt hab^^
Alt 29-03-2007, 14:10
Ich denke EA hat zuerst andere Prioritäten und Problemchen die zu Lösen sind.
Werde das aber mit diesem Eintrag in die options.ini mal heute Abend testen.
Alt 29-03-2007, 14:40
Benutzerbild von Chriz
Chriz Chriz ist offline
Obeliskelektriker
OL Nick: chrizde
Style: GDI
das mit dem Options.ini stammt noch aus Genrals, da gabs die Umschaltung.
Aber das ging in der TW Demo nicht, komisch das es jetzt wieder gehen soll (viellicht wurds teilweise mit 1.1 verändert, ka )
Alt 29-03-2007, 14:41
Patch 1.2 ist bereits auf dem EA FTP:
ftp://ftp.ea.com/pub/eapacific/cnc3/patch12/
Alt 29-03-2007, 14:42
Bekommt man ihn auch schon online übers Game?
Alt 29-03-2007, 14:44
Da ich noch keine 'downloadable Version' gesehen habe, geh ich davon aus, daß er derzeit nur über das Game funktioniert.
Alt 29-03-2007, 15:09
Benutzerbild von gersultan
Pinguin
gersultan ist ein C...
OL Nick: gersultan
aktuell gibt es ingame noch keine Möglichkeit des downloads
Alt 30-03-2007, 00:48
Update Patch 1.2 verfügbar
Der neue Patch ist da!!!
Alt 30-03-2007, 01:01
Benutzerbild von Dr.Death
Dr.Death Dr.Death ist offline
Dr.Death hat noch keine Bewertung oder ist auf 0
Dr.Death eine Nachricht über ICQ schicken Dr.Death eine Nachricht über AIM schicken Dr.Death eine Nachricht über Yahoo! schicken
OL Nick: drdeathdr
und ich kann ihn immer noch nicht downloaden
der sauhund bricht immer ab^^
Alt 30-03-2007, 01:06
Sgt. Pepper Sgt. Pepper ist offline
Sgt. Pepper hat noch keine Bewertung oder ist auf 0
Sgt. Pepper eine Nachricht über ICQ schicken
Also ich hab den 1.02 eben ohne Probleme via Autoupdater runtergeladen.
Erziehung ist die organisierte Verteidigung der Erwachsenen gegen die Jugend.
(Mark Twain, amerikan. Schriftst., 1835-1910)
Alt 30-03-2007, 01:12
OL Nick: drdeathdr
Datei (126 von 139) BÄM bis zur Hälfte komm ich manchmal dann ist schluss^^, na werd ich wohl noch weiter warten müssen
Alt 30-03-2007, 01:15
-=OxiGen=- -=OxiGen=- ist offline
-=OxiGen=- hat noch keine Bewertung oder ist auf 0
-=OxiGen=- eine Nachricht über ICQ schicken
exakt das gleiche bei mir. bricht einfach ab und ich seh keine möglichkeit den manuell runterzuladen wie das bei generals noch ging.
Alt 30-03-2007, 01:20
Benutzerbild von Mitdaun
Mitdaun Mitdaun ist offline
Masterchief
Hatte gerade auch keine Probleme bei den Patch
Alt 30-03-2007, 01:32
Tobias.H Tobias.H ist offline
OL Nick: Tobias.900
Bei mir bricht er schon bei 2/139 ab.
Wieder eine .exe Datei.
Irgendwie kann ich dort keine .exe Dateien laden.
Alt 30-03-2007, 01:42
Bei mir gings auch nicht Fullspeed und zwischendrin kurze Stillstände aber es ging dann doch weiter und konnte erfolgreich beendet werden.
Wahrscheinlich ist der Server etwas überfordert, einfach später nochmal probieren.
Alt 30-03-2007, 01:55
OL Nick: Tobias.900
Ne das glaub ich nicht.
Ist immer die gleiche Datei und bei 1.1 war es auch die .exe Datei,wo bei mir der Download abgebrochen ist. -.-
Alt 30-03-2007, 02:00
Eventuell eine FW oder ein AntiViren Programm das sich zwar nicht meldet aber die Datei solange scannt bis die Verbindung unterbrochen wird?
Alt 30-03-2007, 02:04
Pinguin
OL Nick: gersultan
hört sich jedenfalls fast so an oO
Alt 30-03-2007, 03:14
OL Nick: drdeathdr
also bei mir ist das so....wenn der 125 von 139 ist also bei der cnc.exe dann schmiert der sofort ab....und wenn der direkt irgendwie mit 126 anfängt also (Retail.exe) dann bei 13k kb von 30k kb.
Immer an den selben stellen
Naja mal sehen obs morgen neue Erkenntnisse gibt
gn8 zusammen
Alt 30-03-2007, 06:21
Benutzerbild von fadmax
fadmax fadmax ist offline
Col. Burton
OL Nick: fadm4x
Ich denke mit einer selbstentpackenden Dateien wär das net son großes Problem, naja wie Naos schon im anderen Thread geschrieben hat, noftalls ma den Router abklemmen.
Alt 30-03-2007, 08:06
Winni Winni ist offline
Winni hat noch keine Bewertung oder ist auf 0
Patchen
Habe den 1.2 gerade problemlos heruntergeladen, und er hat sich auch selbstständig installiert.
Die Firewall hatte ich vorsichthalber ausgeschaltet. Was sich als richtig erwies, denn jeder weitere Schritt in den Online - Chat, mußte extra freigegeben werden.
Geändert von Winni (30-03-2007 um 08:10 Uhr).
Alt 30-03-2007, 08:10
Benutzerbild von DaRkCh4MP
DaRkCh4MP DaRkCh4MP ist offline
FüR IMMeR BVB
DaRkCh4MP hat noch keine Bewertung oder ist auf 0
DaRkCh4MP eine Nachricht über ICQ schicken DaRkCh4MP eine Nachricht über AIM schicken DaRkCh4MP eine Nachricht über Yahoo! schicken
OL Nick: DarKCh4MP
jo habs auch ma gucken wie lange ea das durchhält^^
Für Immer BVB
Verkehrsunfall in Dortmund. Ein Sch*lker liegt schwer verletzt im Krankenwagen. Plötzlich macht er die Augen auf und fragt: "Wo bringen sie mich denn hin?" - "In die Pathologie." Beschwert sich der Sch*lker: "Aber ich bin doch noch gar nicht tot!" - "Jaaaa - wir sind ja auch noch nicht da."
Alt 30-03-2007, 08:24
Mannmann, ich muss ja krank sein, noch vor dem Frühstück in der Unterhose erstmal nachzuschaun ob der Patch drausen ist
Autoupadate Funktion hat bei mir wieder nicht geklappt!
Gott sei dank haben sie ihr Versprechen gehalten und bieten zusätzlich eine exe an. Mit der hats wunederbar funktioniert. Bei einem ersten Test kam ich ohne Proleme online.
Pfad > ftp://ftp.ea.com/pub/eapacific/cnc3/
Fein
Alle Zeitangaben in WEZ +2. Es ist jetzt 01:41 Uhr.
