Those of you who purchased The First Decade game pack way back in February of 2006 are still waiting on EA to fix some of the problems with a new patch (V1.03). While I don't put much hope on ever seeing another patch for TFD from EA (last one was April 2006), someone in the community stepped up to the plate and pinched hit.
According to Banshee from Project Perfect Mod, VK has released a patch for the original Command & Conquer, labeled (V1.05). This patch supports both the TFD version and original C&C version. The fixes to the game in his patch includes making C&C fully compatible with WINXP (no need to set "Windows 95 compatible mode"), and a fix for lan games support. The map border crash was also taken care of with VK's new patch. Those of you who downloaded the FREE C&C Game being offered by EA for the month of September, just apply the new V1.05 patch to it.
Head to Project Perfect Mod for more info and the download.
Auf Deutsch:
Laut oben stehender Info sorgt dieser Patch dafür, daß C&C - Der Tiberiumkonflikt bzw. Tiberian Dawn (sowohl in der originalen Version als auch in der in TfD) nun komplett mit XP kompatibel ist. So ist keine Kompatilitätseinstellung auf Windows 95 mehr erforderlich. Außerdem gibt es nun auch LAN Funktionalität! Zudem behebt er das leidige Problem der Abstürze wenn die Maus an den oberen Bildrand gelangt (viele von euch haben diese Erfahrung machen müssen).
Hier nochmal das originale Patchlog:
Command & Conquer 1.05 Update
This update can be applied ONLY to C&C95 V1.04.
(another popular names are: Command & Conquer GOLD, Tiberium Dawn,
Command & Conquer for Windows)
Supported both: TFD version and original version.
Non-original files not supported at all.
1.05 update info:
The source of updated THIPX32.DLL file:
http://www.understorm.net/thipx/thipx32.dll
Web-site:
http://www.vk.cncguild.net
-VK"
1.05 update info:
- Command & Conquer now Windows XP compatible!
- You no longer need to set "Windows 95 compatible mode"
- Included updated THIPX32.DLL file, which fix LAN games support.
- Map border crash no longer happen.
Web-site:
-VK"
Ein Hinweis in eigener Sache: Bitte bedenkt, daß dieser Patch nicht offiziell ist und deswegen bei Problemen auch kein Support zu erwarten ist!
Download C&C Gold Patch 1.05
Quelle: CnCDen.com
