Welcome Back, Comrade!
After seven years, Red Alert is returning with Command & Conquer™ Red Alert™ 3. Be among the first anywhere to play one of the most highly anticipated games of the year by joining the Command & Conquer Red Alert 3 Beta program.
The first step towards participating in the Beta program is ordering Command & Conquer 3: Kane’s Wrath. Not only will you get to play the latest installment of the Command & Conquer 3 Tiberium Wars Saga,, but within every purchase of Command & Conquer 3: Kane’s Wrath that contains the Red Alert 3 Beta Key Sticker is a key that guarantees you access to the Command & Conquer Red Alert 3 Beta program if you register before September 15, 2008.
How the Program Works:
Once you receive your copy of Command & Conquer 3: Kane’s Wrath, look for the Command & Conquer Red Alert 3 Beta Key Insert and visit the designated website.
To reserve your spot in the Beta program, you will follow the directions to register with the code printed on the Beta Key Insert.
Once you have registered, you will be entered into the Beta queue. Depending on when you register and your location, you will be called upon to activate your Beta key at any given point during the Beta program. Once that time comes, you will be contacted via email with instructions for downloading the Command & Conquer Red Alert 3 Beta client. You must download the client within the time period indicated to you in the email.
By ordering Command & Conquer 3: Kane’s Wrath and registering with the Beta Key before September 15th, 2008, you are guaranteed a chance to play the multiplayer Beta before Command & Conquer Red Alert 3 releases.
Be one of the first people to experience the revolution. Order Command & Conquer 3: Kane’s Wrath today!
