Hey guys,
I just wanted to give you an update with the Renegade lag issues currently being experienced by our Gamespy players.
Thanks to your feedback, we have located the major problem causing severe lag and are working to rectify it as fast as we can. We`re set to burn the midnight oil and get this fixed, tested, and released to you as soon as possible. In addition to addressing the lag issue, we`re going to also adjust a few more settings which will allow you to again host non-dedicated servers. I don`t have an exact timeframe yet, but we`ll keep you posted as we know more.
Thanks for your patience and understanding in helping us make the Renegade demo the best it can be.
~d.
Sie haben demnach das Feedback das viele User gepostet haben dazu benutzen können um den Grund für den Lag zu finden und arbeiten derzeit daran die Ursache zu eliminieren. Ferner planen sie einige Einstellungen hinzuzufügen die es wieder ermöglichen sollen Server zu hosten - sofern diese nicht Dedicated sind. Devinoch hat noch keinen genauen Zeitplan wann der Patch kommt, wird uns aber auf dem Laufenden halten.
