Ihr könnt, wenn ihr euch traut :D den Patch bereits jetzt von Fileplanet saugen:
Demo Patch 1.007
Ihr könnt aber auch bis morgen warten, dann wird er wohl auch auf dem FTP Server von Westwood zur Verfügung stehen...
Vorab der Link: Westwood FTP
LIST OF CHANGES IN THE 107 PATCH
1. Found and corrected a problem creating extensive lag.
2. We turned off the dedicated server requirement.
Any player can host a game now, Renegade will simply limit the
number of players to an acceptable level (ex. a 56K modem can
serve up 2 players, cable modems can serve 4 to 8).
3. Reduced the bandwidth test.
Once the bandwidth test has determined an appropriate number it will
present the user with a "SKIP" button which will speed up entry into
a game. This is provided as a convenience, we do not recommend you
use the button because your bandwidth on any given day will vary,
and the more accurately the server knows your bandwidth,
the better the game will play for you.
4. Reduced time spent in the initial splash screen.
The first time you see the splash screen it will stay up for 4 seconds,
after that it will up for a minimal (if any) amount of time. This was
done to facilitate entry into the game.
5. Fixed a bug that was creating instability in the server.
6. Added a version check. If you join a server that does not match your
version you will receive a "Version Mismatch" dialog.
Kommentar von [¤/]-=l{µll{µ§=-.
hoffe aber das der gesammte spielablauf bis zur FULL noch erheblich besser wird, ab undzu verhakt man sich in bäumen--meint weiterzufahren und zack steht man wieder vorm baum...kann man sich wie lag vorstellen ((?)) löl
OvEr
