** YURI`S REVENGE MAP PACK #3
** RELEASED 4/19/2002
** COPYRIGHT 2002 ELECTRONIC ARTS INC. ALL RIGHTS RESERVED.
** INSTRUCTIONS **
Simply copy the 2 maps included in this zip into the directory in which you installed Red Alert 2/Yuri`s Revenge. Once the files have been copied into the directory, load Yuri`s Revenge and check the list of maps available to you in multiplayer. You should see your new maps.
Moon Patrol
(2-4 Player Map)
Heavy Resources (Gems)
Environment Conditions: Lunar
File: MoonPatr.yro
Features:
Moon patrol takes place on the lunar landscapes of our very own moon. Cosmonauts are available on this map, so it will be wise to build some good air defenses.
Unrepentant
(2-6 Player Map)
Medium Resources (Gold, oil)
Environment: Temperate
File: Unrepent.yro
Features:
This is a straight six-player map for designed for FFA and team play. The gold is spread evenly all throughout the map, players will also find oil derricks.
Tip: Secure the oil to help gain and secure territory.
Das Pack wurde nicht einmal auf der offiziellen Site angekündigt :O
Download MapPack3
Kommentar von Mr.X in Spee.
Kommentar von Mr. X.
Kommentar von Trunks.
Kommentar von der kann als alli ne sowjet einheit baue.
Kommentar von Blackhawker.
