VERSION 1.01 FIXES
1. Bug that caused some buildings to not show up in Windows XP.
2. When deleting trigger actions, the trigger often became corrupted.
3. FA2YR always used the old RA2 strings instead of the new YR strings.
4. You were unable to place trees in the NewUrban theater.
5. User script "Add Reveal Map Debug Trigger" was broken.
6. Bug that caused crashes when quitting FA2YR.
7. Singleplayer Map Tutorial didn`t consider Yuri`s Revenge maps.
VERSION 1.01 CHANGES
1. FA2YR now reads "Expandmdxx.mix" files instead of "Expandxx.mix" files, as long as RA2 Mode is disabled.
2. Team Alliance mode is now supported.
Die neue Version gibt`s FA2:YR1.001 (2,5MB)
Kommentar von first.of.six.
:D:cool::D
Kommentar von Der C&C Master.
