IGNPC: So how does the new system work?
Mark Skaggs: We made supply depots that are placed around the map. Each side collects resources from them differently. The US sends a Chinook helicopter out to pick up from it. Now think about that for a minute. It flies over so it doesn`t have to worry about ground units, but it is vulnerable to air attacks so you have to look out for those. The Chinese have the supply truck which is, of course, on the ground so it is vulnerable to ground attack, but it is tougher and cheaper.
IGNPC: Will you have to fight to control the supply depots?
Mark Skaggs: Yes, that is the idea, so you will have to maintain control of these areas if you want to get resources from them, which is of course very important. It is similar to the Tiberium patches in that you must control the area.
Das komplette Interview findet ihr hier
Kommentar von Dam0kles.
Kommentar von NickParker.
Kommentar von Werkzeug des Untergangs (EEBKiller).
