Hi Dave,
Please pass this along to the community?we?re making some fixups. We added?
-directory
As a command line option; this will allow you to specify a directory that would take precedence over all other INI & BIG files (but not prevent parsing of any of them).
This means that total-conversion modders can now put all of their custom stuff into a single directory (or bigfile) and not have to disturb the existing file structure in any way; they merely have to launch the app with a different command-line option to run the mod in question.
--Harvard
Demnach werden Modder die Möglichkeit eigene BIG files oder Ordner anzulegen und diese über ein Kommando beim Starten von Generals zu verwenden. Das ist mal echt ne praktische Änderung, weil man die anderen BIGs dann nicht back-uppen muss. :)
