Dear C&C Generals players,
We`re continuing to hammer out Patch 1.4. It`s looking really good so far and we`re on target for release early next week. Most of the work is done and we`ll be testing till then. Here`s a tentative list of the contents. It may change depending on how testing goes but it should give you a ballpark estimate on what to expect. We`ll keep you up to speed on the progress.
TENTATIVE 1.4 LIST
- Fixed the "repeat games in the custom match game list" problem.
- The game can now track who the offending disconnector is in a game. That player will get a loss and also lose a rank point.
- Changed the lobbies to only list the games contained in that lobby. Also renamed all of them after different countries...USA, Germany, Korea, UK, Australia, China, Europe, Asia, etc.
- Fixed a problem where the user could sometimes lose connection to Generals Online.
- Increased the allowed time for game to negotiate matching between players.
- Added the 3:00 rule for a game to count on Generals Online.
- Made a change for modders...added ?directory command line.
- Fixed the rank hack where some players appear to have a higher rank than they should.
- Fixed the "no artwork" problem for a Random Private.
- Fixed an autosave problem in the Korean/Chinese versions.
- Fixed a crash related to user DPI setting.
- Added a new multiplayer map.
- Made some balance adjustments (may change):
* Tunnel Network build speed decreased.
* Marauder Tank hit points increased.
* Stealth Fighter hit points increased.
* Explosion damage done by Chinese Nuke Tanks when they are destroyed reduced.
* Nuke Cannon locomotor changed so it moves the same speed when damaged, not faster.
* Aurora speed increased after it drops a bomb. Damaged speed increased.
OTHER THINGS WE`RE LOOKING AT
- We continue to track down serious error issues. We are working with people who write to seriouserror@ea.com.
- We continue to look at firewall issues.
- We`ve been keeping an eye out for online trainers, cheats, etc.
- We`re working on the ladder kit. See previous post for status.
- We`re working on a help bot for the lobbies.
- We`re making more multiplayer maps.
I hope all this gives you some insight into the work being done. Thanks for your continued support.
Kommentar von Trunks.
Kommentar von dondaggi.
Das Ding is eh kakke und viel zu teuer:angry:
Und macht kaum Schaden wird nach §sek gesehen und abgeschossen:angry: Voll der Fuck
Kommentar von se7en.
1. 3 Minuten sind zu lang, m.E. reicht sogar eine Minute... die hätte ich auch gerne wenn einer wie die Sau laggt (was man ja beim Laden meist schon erkennen kann)
2. CLAN-Support... ist der im Ladderkit drinne???
Kommentar von Bogul.
damit wird endlich mal der gla der wind aus den segeln genommen, grade der build speed bei den tunnel netzwerken hat mich schon öfters zum verzweifeln gebracht :)
das mit den 3 minuten ist allerdings doof, da man deutlich früher gewinnen kann bzw. das spiel entscheiden kann und der gegner so grad die möglichkeit hat für umme das spiel zu verlassen. Sollten meiner Meinung nach maximal 2 minuten sein, aber da wird man wohl eh nix mehr ändern können ...
aurora bomber war nach bomben abwurf wirklich viel zu langsam, gut dass das geändert wird :)
Kommentar von Narodnaja.
Kommentar von EEBKiller.
Kommentar von Martinator.
Wie wollen die das machen? Die Stats werden doch nur auf der Festplatte gespeichert!?!
