Liste der derzeit bekannten Bugs
Sven • Mon 17 im Mar, 2003[09:17 GMT]
Harvard hat auf dem Generals Board eine Liste der derzeit bekannten Bugs veröffentlicht:
1. STAT RECORDING INACCURACY: Is legit. We are working on it.
2. SELL BARRACKS EXPLOIT: Is legit. We are working on it.
3. BUGGY MISSILE TRACKING AFTER UPGRADE: Is legit. I am consulting with design to decide on the best course of action.
4. GLA CAPTURE POWER BUG: Yes, if the GLA captures a power plant they build faster. Working on it.
5. GLA LOW POWER OVERALL: This is a tricky one. The assessment of the ini numbers is correct. Thing is, its been that way since the get go and has been incorporated into the balance since the start. I will consult with design and will look at more closely. Might be something that we do not adjust.
6. MiG BLACK NAPALM: Is legit. We are working on it.
7. GLA FAST BUILD BUG: Yes, you can make the GLA build faster using this exploit. We are working on it.
8. MAKE DEMO TRAPS REQUIRE BARRACKS, NOT ARMS DEALER: Consulting with design. Might be a good idea.
9. BOMBARDMENT DOESN`T AFFECT AIR UNITS: This is legit but I`m consulting with design to see how we`ll address.
10. EARLIER REPLAYS DON`T WORK AFTER 1.4: We are checking on this. Not sure why it seems to fail now but will inform everyone when I know.
11. CASE`S LADDER IMPROVEMENTS: Working with Case`s to address the issues listed.
12. SOME PEOPLE DIDN`T GET THE OFFICER`S CLUB: Check with Customer Service. They will send you one. If the retailer didn`t give you one then we`ll make sure you`re taken care of.
13. COMMAND BAR MISCLICKS: The game registers clicks like Windows. It`ll register when the button rises again after a click, not at depression. We are looking at and will address.
14. STUCK TOMOHAWK MISSILES: Looking at it.
15. SERIOUS ERRORS: We`ve fixed many of them but please continue to send your info to seriouserror@ea.com with your EAsy Info. We`ll try to help as many of you as we can.
16. VARIOUS ROUTER & CONNECTIVITY ISSUES: We continue to work on these.
17. GENERAL BALANCING ISSUES: We know full well of the initial reaction to the changes made. We`re continuing to evaluate and will make a change if any of the sides turns out too nerfed. Please understand that its important to be patient while the changes get a bit to settle in.
Kommentar von DeluxE.
von admin, Saturday 29 im March, 2003[10:48:53 GMT]
Kurz nach Spielbeginn explodieren alle meine Gebäude und ich hab verloren!Hat jemand ne Arnung wovon das kommt??
Kommentar von PIN.
von admin, Monday 17 im March, 2003[21:14:20 GMT]
ach noch wat ... es is exrem gagge das die gba tunnel jetzt langsamer bauen die GBa is nu voll am arsch ( seht euch ma die prozente an ,und es werden mit sicherhet noch weniger)
NEUER PATCH muss heraba diesma einer der och funzt
Kommentar von PiN.
von admin, Monday 17 im March, 2003[21:11:59 GMT]
@trunks bekommst du och imma disconnects wenn du gewinnst????
Kommentar von Trunks.
von admin, Monday 17 im March, 2003[20:40:17 GMT]
@Pin ich bekomme keine wins und keine losses...nen neuen acc. kann ich auch nicht erstellen also müssen wir wirklich noch warten...
P.S. ich glaub kaum das das alle Bugs sind.
Kommentar von EEBKiller.
von admin, Monday 17 im March, 2003[19:24:48 GMT]
Abwarten und Tee trinken :angry:
btw: Ich denke, die Bug-Liste ist noch um ein vielfaches länger - danke EA! :angry:
Kommentar von PIN.
von admin, Monday 17 im March, 2003[16:04:55 GMT]
1.4 is sooooooooooooooooooooo scheisse grrrrrrrr seid dem assipatch geht bei mir nix mehr:(
jeder win wird bei mir als disconnect gewertet (tolle sache hab jetzt 32 disconnects aufm konto)
kannn mir ma einer sagen wat ik da machen kann damit es allet wieda funzt? ok thx;)
