Hello Guys and Gals,Es wird also im Wesentlichen um die Probleme der Anwender gehen die Firewalls und/oder Router benutzen. Es scheint vor allem Probleme mit modifizierten "options.ini" Dateien zu geben.
Just wanted to let you know that we are still working hard on patch 1.6.
Let me recap what`s being worked on:
We are testing the firewall/router fix that I had mentioned before. We believe that the problem lies within editing the options.ini file. If everything works out the way we suspect, this fix should be of great help to those whose routers/firewalls don`t work with Generals by default. I don?t want to go into a lot of detail here until I have more definite information about the fix and that it will actually cure the problems that we are hoping it will.
We are still looking at the Data Mismatch issue. We`ve received some replays that were submitted by players within the same game and are in the process of reviewing them. I`ve forwarded the information that many of you have contributed here. A lot of you seem to think that it`s related to selling a Command Center that is under attack which we`ll be looking at.
There is also a list of gameplay issues that we`re addressing as well. Harvard has addressed some of them in his post here: http://messagebrd.westwood.ea.com/cgi-bin/boards/gen/ultimatebb.cgi?ubb=get_topic;f=8;t=000049
Please be patient as we are taking more time with this patch to allow for more fixes. I know that these are trying times for those of you that are awaiting some of these fixes, but be assured that we are working on them.
Thanks,
Col. Burt
Production Support Technician
Desweiteren überprüfen sie was die Ursache für die auftretenden "Mismatch" Fehler sein könnte und konzentrieren sich darauf daß es mit dem Verkauf von Gebäuden zusammenhängen könnte.
Auch gefixt werden wohl eine Reihe von Gameplayproblemen und -bugs, für mehr Infos folgt obigem Link.
