Gamespot:
On the GLA side, you`ll be able to control the new combat cycles, which are basically dirt bikes. The function of the combat cycle changes if you take an existing infantryman and swap him for the driver. Put a terrorist on the bike and he becomes an extremely fast suicide bomber. Put Jarmen Kell on it and you can snipe from the bike. Aside from being fast, the combat cycles have the ability to drive off the edge of cliffs, which lets you take shortcuts across the map and possibly sneak behind enemy defenses. Another new GLA vehicle is the battle bus. These look like beat-up old buses, but they serve as rolling bunkers. Infantry can shoot out of them, and, after it sustains some damage, the bus loses its wheels and becomes a stationary bunker, shielding the infantry inside from damage.
IGN:
The lone Chinese General in the game as of yet is Tsing Shi Tao. This guy is a master of the nuke. He loves his nukes. Everything that he uses has some sort of nuclear capability. His regular tanks shoot nukes and spread radiation. His rocket launchers shoot tiny nukes that also spread radiation. Pretty much everything he does spreads the stuff. And the best part for him is that all of this stuff is cheaper and more powerful than it normally would be. But like the rest he`ll take hits in other departments. Even with their cheaper costs and higher power for certain units, the fact that they`re restricted from certain technologies could make these armies just as tough to play with online against the regular forces with a full and balanced attack. Certainly, not being pigeonholed into one type of strategy allows for changes that the Generals will not be able to make.
Sorry, ist mir zu lang zum übersetzen... :D
Aber interessant ist es in jedem Fall.
Kommentar von baboon201.
Kommentar von Offroader.
Nicht jeder kann das :)
Kommentar von pY.
Kommentar von Mackemi.
