So, grade vom offiziellen Baoard gekommen, aber etwas zuviel zum übersetzen:
Dear C&C Generals players,
As noted in the header, the patch will be out Monday. Below please find the readme. We apolgize for the delay and appreciate your patience.
1. FIREWALLPORTOVERRIDE INI ENTRY - repaired this entry so it functions correctly. See section 2.1 of the Readme for more information on using this INI entry.
2. ALT-F4 MULTIPLAYER EXPLOIT - Quitting the game during a multiplayer match using Alt-F4, as well as Ctrl-Alt-Delete or the Alt-Tab menu, will now correctly give the user a disconnect stat.
3. CHINESE AND KOREAN IME WINDOW ORDER - Re-prioritized the Korean and Chinese IME windows on the Save/Load screen so they now sort on top of all other windows.
4. SCUD STORM ANTHRAX BETA BUG - GLA?s Scud Storm now has the correct damage radius when upgraded with Anthrax Beta.
5. CHINA GATTLING TANK BUG - China?s Gattling Tank now correctly moves slower when it is damaged.
6. MULTIPLAYER LOBBIES ? The lobbies have been renamed to allow people to congregate based on the type of game they want to play, not their region. These lobbies are:
? 1 vs 1
? 2 vs 2
? 3 vs 3
? 4 vs 4
? Free4All
? ClanWars
? Asia
? Europe
? N America
? No Supers
? Mod Maps
? Newbies
7. GENERAL BALANCING ISSUES:
? China?s Gattling weapons now require Line of sight to fire.
? China?s MiG cost increased from 1000 to 1200.
? China?s MiG Armor cost increased from 500 to 1000.
? US?s Cold Fusion Reactor Control Rod upgrade cost decreased from 800 to 500.
8. QUICKMATCH RESOLUTION ? The resolution for QuickMatch games is no longer limited to 800x600.
9. BEHIND BUILDINGS GRAPHIC - Addressed a problem where unit occlusion was causing people with older video cards to see invisible units.
10. ALTERNATE MOUSE INTERFACE - Added feature to allow players to play with ?right click action? interface. Movement and actions are handled via right click on the mouse. Also changed arrow keys to support map scrolling.
11. GEFORCE FX GLITCH - Fixed a glitch that caused some graphics corruption to appear for owners of NVIDIA`s GeForce FX video cards.
12. CRASH FIX ? Fixed a crash that occurred when you disable the ?behind buildings? feature in the advanced options, exit the game, re-enable the feature in the advanced options, and then load a map.
13. CHEAT HACKS ? Fixed the ability for players to cheat by giving themselves automatic build, upgrade, and Generals powers buttons. Also fixed the ability for players to hack their Generals points in multiplayer games.
Harvard Bonin
Producer
Kommentar von beidel asso.
Kommentar von Darkwolf.
Kommentar von pY.
Kommentar von pY.
Kommentar von Hag der Hunnenkönig.
Kommentar von Chriss.
Kommentar von Junker.
