Some FYI
We know about the problem where every time a message comes up there is a ping sound.. We?ll fix in the 1st patch.
There were many improvements to the disconnect code, but there is still one known issue. If you are in a game that ends in a mismatch, you will get a disconnect in your stats. This is as designed and will not be changed.
We believe that we fixed the China Command Center CRC and the Map Hack. These are in Patch 1.7 for Generals.
We are looking into the Radeon card problems, although we are having a hard time replicating them. We tested several Radeon cards and didn?t have any problems, so it must be a specific configuration causing the problems. We are continuing to investigate and will put into the 1st ZH patch if we can reliably duplicate it.
If you are having CD key problems, please contact Customer Support. Development doesn?t deal with CD keys. This If there is a problem, it could be from manufacturing.
Regarding the FMV?s being jerky. We do not load and play the FMV?s at the same time. We play the FMV, then load. To save hard drive space, the FMV?s (Bink movies) are loaded from the disc, not the hard drive. If it is jerky the first time through, try restarting the mission. As with many kinds of videos, the first play-through is sometimes jerky.
Es gibt demnach Probleme daß immer ein `Ping` Geräusch zu hören ist wenn jemand eine Nachricht schreibt. Dies wird im ersten Patch behoben.
Beim `Disconnect` problem wurde viel getan, dennoch gibt es noch eine Sache: Wenn das Spiel mit einem `Mismatch` endet so bekommen alle einen Disconnect. Dies wird auch nicht geändert werden.
Das team ist der Ansicht daß sie es geschafft haben den China Hauptquartier CRC Fehler und das Maphack Problem zu lösen, dies wird auch in Patch 1.7 für Generals einfließen.
Zu den Problemen mit Radeon Grafikkarten sagt EAComMike daß sie Schwierigkeiten haben das Problem zu reproduzieren, es scheint an einer bestimmen Konfiguration zu liegen. Das team wird das Problem in einem Patch beheben wenn sie es sicher reproduzieren können.
Wenn ihr ein CD Key Problem habt, wendet euch bitte an den Kundensupport, das Entwicklerteam hat damit nichts zu tun.
Auch scheint es ein Problem mit den Videos zu geben. Diese werden von CD gelesen und das Problem sollte aus der Welt sein wenn das Video zum zweiten Mal abgespielt wird.
Wenn eure Videos als stottern, dann ladet die Mission einfach neu.
